Old 05-18-2012, 11:22 AM   #51 (permalink)
Originally Posted by TroyVX View Post
Well I got the "L00" ECU and installed it and the car runs great. It was a plug and play deal which made it nice. I'm going to get it smogged in the next few weeks. So I'm happy for now, I'll let you know if it does or doesn't pass the Ca smog test.
Well after all of the work on this car it PASSED Ca. smog test and the tech told me that the car runs cleaner than 85% of the cars in it's classification. WooHoo the car is now in my name!!!!!
Old 05-18-2012, 12:18 PM   #52 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That's a great result. Congratulations!
Old 05-18-2012, 01:52 PM   #53 (permalink)
Originally Posted by steffen707 View Post
What "shudder" feeling are you talking about? The shudder when the car goes out of lean burn and into regular mode?
..exactly...I seem to notice it going into and out of LB....at least in the Insight...which has a meter that confirms LB mode...
Old 06-18-2012, 04:20 PM   #54 (permalink)
Does anyone know if I can harvest these connectors from a complete civic 92-95 engine harness? I've seen harnesses on eBay and figured I could just buy one of those to get the 4 needed connectors but I don't know for sure. Thanks!
Old 06-18-2012, 11:07 PM   #55 (permalink)
Patina - '80 Vespa P 125x
90 day: 67.27 mpg (US)
nonya - '00 honda insight
Gen-1 Insights
90 day: 67.62 mpg (US)
You can harvest them, but avoid eBay if there is a junkyard in your area. I bought all of the terminals/ connectors I needed for around 5 bucks and spent a couple hours splicing it all together. Finding a legit vx harness is hard. But using the connectors from other crashed hondas( not just civics btw) is doable. Finding the ecu in the junkyard was the only part I couldn't find. Good luck
The Following User Says Thank You to backsidesnap For This Useful Post:
aarunt1 (06-19-2012)
Old 06-19-2012, 12:48 AM   #56 (permalink)
Thanks! I'll do that then. I guess there is a scrap yard close to my parents and by my house. I should be able to find the 4 connectors out of those 2 places I'd think. I just bought a federal ECU and an 02 sensor so once I can make the cable I'll be good to go!
The Following User Says Thank You to aarunt1 For This Useful Post:
getnpsi (10-03-2012)
Old 08-18-2013, 11:27 AM   #57 (permalink)
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
I just purchased a 94 Civic VX California version. I will be driving it to Colorado where I live.
I was looking to do the Federal conversion and I have read through your thread as well as a few others on the net.
I have two questions about the conversion.
1.) If I find a 5 wire O2 sensor, wire harness and Federal ECU will it all be "plug and play" on my VX without having to make/create a custom wire harness?
2.) I have read about needing a Federal version intake manifold and EGR control box to make this conversion complete. Are those two things necessary?
ZO.
Old 08-18-2013, 11:38 AM   #58 (permalink)
You'll need the wiring harness, 5wire sensor and the computer, that's it.
I made my own wiring harness, using Honda connectors, and it's all plug and play.
I'm going to sell my red 93 cali VX, since I found a white Federal (with shift light). The white one is going to be my back up daily driver, and I don't need anything fancy. That said, I don't think I'll be adding a lot of value telling someone it's a federal version. I can always keep the new 5 wire sensor as backup.
Old 08-18-2013, 02:26 PM   #59 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 51.85 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Yep, AZVX has it right.
Old 08-19-2013, 03:12 PM   #60 (permalink)
Kai Spec Motoring VX - '94 Honda Civic VX
90 day: 50.98 mpg (US)
No need to source a Fed Vx engine harness. Just follow the DIY, it's very easy. And the shift up light. Forget about it, use the MPGuino. Best tool for driving fuel efficiently.
5-wire o2 sensor, ca to fed conversion, civic vx
lean burn rules~! coolwHip Introductions 42 10-01-2011 06:42 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 03:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
Craigslist Milwaukee: '97 Civic HX lean burn love MetroMPG For Sale 0 02-05-2009 05:02 PM
VX lean burn Nden DIY / How-to 11 12-05-2008 10:01 AM
