07-24-2013, 10:24 PM
#51 (permalink)
halos.com
Originally Posted by tony_2018
What are your gains with the underdrive pulleys, are they the Lightweight?
Unfortunately, the wind won't stop blowing long enough so I can get the truck out for some testing. So, I can't give you any data. I can tell it freed up some HP. AIRRAM's website says the underdrive is worth 7-8 hp, if I remember correctly. Yes, it is 3 pounds lighter than the OEM pulley. I weighed them both.
[edit] I've driven my truck without the belt turning the power steering pump. Above about 20 mph you can't tell the difference...
07-26-2013, 01:57 AM
#52 (permalink)
Originally Posted by oldtamiyaphile
What happens if you're cruising down the highway and have to swerve?
Turn the wheel, at highway speed there is surprisingly little difference between P/S and no P/S.
With no P/S you are less likely to over correct.
I take it you never tried driving something with no P/S.
07-26-2013, 08:06 PM
#53 (permalink)
halos.com
Originally Posted by justme1969
This must be another new thing as I worked at auto stupid back in 97 and 98 and they did sell them then. I will explore this a little.
Mabe just a sorry sales person, I also get them most of the time.
Look for an auto stupid in amongst or near dealerships, that is going to be a supplier yes your genuine GM ends up being guess who lots of times?
I just checked on Ebay, searched for ac compressor clutch...and it seems you can buy one now! New AC Compressor Clutch Jeep Grand Cherokee 1999 2004 6CYL 6GROOVES | eBay
Hmmm, might have another project to undergo now.
(edit) Frank, which vehicle are you NOT using the power steering? On my truck it's rather difficult to turn from a stand still (not good with golfer's elbow). But if I could remove the entire ps system, that weight savings would be nice. And, I forgot, when I tried it, I left all the fluid in the system and all the hoses connected. If I'd connected the rack to itself, I think it would have been easier to steer.
07-26-2013, 08:24 PM
#54 (permalink)
Cyborg ECU
Good luck performing a swerve and recover manouver at speed w/o PS.
This is not an issue at anything over a few MPH. I have been driving my 98 Civic DX without PS for over two years now, 30K miles. As Frank Lee and others with experience will tell you, you'll only really feel a difference at stationary or a few mph.
07-26-2013, 08:39 PM
#55 (permalink)
The "Sport Coupe" Tempo.
I'm always coupling/decoupling from trailers with the F150 so the power steering is going to stay on that one. Plus I don't think it'll make a noticeable fe change on it.
Got a Tracer I'd like to hit 50mpg with; best fe was 42 so I'll have to see what it'll take to bypass the power steering on that one.
07-26-2013, 10:02 PM
#56 (permalink)
Yes, I take back what I said earlier. I drove many miles with a non PS 4.1 Ford and held many a slide. I was thinking about the van I just bought that hardly steers with PS and I have yet to get to the bottom of that.
I was also thinking that simply disconnecting the PS pump makes the steering heavier than if the car originally had manual steering, as the ratio is usually different, but I realise it's only 10-20%.
In fact I have a spare A/C unit with clutch
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
07-28-2013, 05:36 PM
#57 (permalink)
Wiki Mod
having driven with a "broken" PS system for 9 months or more, at any speeds over 15 MPH its hard to tell its not there. at low speeds it just takes more effort to turn the wheel.
07-29-2013, 08:21 AM
#58 (permalink)
OK I dont really have the time to research it properly but there are some options I think I would go to a upull it myself, just so that I could match shaft size to clutch because from limited memory we stocked 11 diff clutch assy. back then.
12V Auto Air Conditioning Clutch For TOYOTA Coaster (AC.106.002)
Santech/Clutch hub for Denso 10PA (MT2302) | A/C Clutch and Parts | AutoZone.com
I have not tried JC whitney either but NAPA showed one in first 10 pages for old school dodge.
If I could only recall the name of the company????
Sorry folks thats my best ten minutes without including e-bay or similar searches.
Also that NAPA unit was a first 10 pages search probbably more in there.
07-29-2013, 09:58 AM
#59 (permalink)
For a large vehicle like a full size pickup or big SUV I calculated that it will only offer about a 1/2mpg improvement on the highway.
If you can do it (delete or clutch the P/S) for under $100 it could be worth it.
07-29-2013, 11:34 AM
#60 (permalink)
It would be awesome for a throttle sensitive switch mabe disconnect @ 1800 rpm? Not sure application is key but a toggle switch to flip on when parking would be Jazzy for my app.
But the undieing POS KIA needs none, I cant even remember what that car felt like with it now. Also for the others it has no issue about control steering or panic motions its rack n pinion unit probbably does better in those applications without due to true feeling for response.
