Old 03-07-2018, 02:40 PM   #471 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
I like plain and simple over too artsy
Old 03-07-2018, 03:34 PM   #472 (permalink)
"So you're saying..." you prefer corporate logos over planished sheet metal?
You can't be wise and in love at the same time. -- Bob Dylan
Old 03-16-2018, 03:22 PM   #473 (permalink)
ChopStix's Avatar
Old 03-17-2018, 12:15 PM   #474 (permalink)
ChopStix's Avatar
Old 03-18-2018, 04:15 PM   #475 (permalink)
This was prolly posted before, but Jason Torchinsky wrote it up:
https://jalopnik.com/you-could-once-buy-a-volkswagen-powered-boat-from-your-volkswage-dealer
The best one is the Typ Delphin, you'll see when you go there.
Old 03-19-2018, 06:24 AM   #476 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
not suprising, the flatfour issa versatile engine. And with the typical mild-cam, they are fairly reliable with regular service. Though they hold up pretty well under abuse too, if you just dont let it run lean
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 03-19-2018, 01:02 PM   #477 (permalink)
The 36hp was legendary. Cylinder #3 was the weak link. I ponder what one could do with a 3D scan of that cast aluminum lower shroud and a printer.
Old 03-20-2018, 03:18 AM   #478 (permalink)
The windscreen I sketched out at Permalink #455 is in progress. I mocked it up first with PVC pipe to get the dimensions. Then I tried strips of redwood. Better, but the third attempt is curved metal strips intended for putting 1 1/2" radius edges on sheet rock.
I'll cover it with 4mm poly for photos. Ultimately it should be Lexan or rusty perf metal with a flip-down hatch like a scout car.
http://justacarguy.blogspot.com/2018/03/i-bet-this-would-be-huge-traction.html
ChopStix (03-23-2018), Fingie (03-25-2018)
Old 03-24-2018, 03:37 PM   #479 (permalink)
I'm too lazy by now to post pictures of some Kombis I saw earlier this week...
Old 03-24-2018, 04:23 PM   #480 (permalink)
But not too lazy to post that you're lazy?
Not a Folksvagen:
http://justacarguy.blogspot.com/2018/03/i-had-forgotten-all-about-indy-500.html
