Old 02-19-2015, 09:40 AM   #121 (permalink)
Originally Posted by Baltothewolf View Post
Doax, can you make the wires like 3 feet if it's okay? I don't know if it's possible but it would be nice.
I can do that, but it will be a pain to install. As it is with the shorter 12" leads, its kind of a pain to keep the wires from wrapping around the shifter shaft as you install it (screwing it on takes a lot of turns). With that long of leads, it'll be an even bigger pain. I would suggest using short leads, and putting some crimp on connectors on the ends so you can just plug it in once you screw it on. Thats what I'm doing with mine.
Old 02-19-2015, 09:54 AM   #122 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Great. Now I need to find a clockspring for my shifter!
Transmission type Efficiency
Old 02-19-2015, 10:24 AM   #123 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... I read http://ecomodder.com/forum/showthrea...vic-18242.html and it specifies NO, but not amps. ...
Fwiw, I think my switch, which you refer to above, is called a NC or normally closed switch, because it's normal position is to close the circuit and allow current, pushing the button "opens" or breaks the circuit. As for amps, there are none to consider, if I understand correctly, because I cut the ground wire only. A reason for that was concern that fraying of the insulator miht eventually allow current to make contact with the metal shifter.
Old 02-19-2015, 11:36 AM   #124 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I never thought about that, yea I'll just use crimp connectors, thanks! Any idea when you'll be done making it?
Old 02-19-2015, 12:36 PM   #125 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Balto,
I would advise using twist on caps the first time you put it together and giving it a test drive before you crimp it on. I had my regen button and the clutch switch swapped when I first put it together, and if I had installed them with crimps the first time it would have really sucked!
The first test drive was kinda funny, as soon as I hit the clutch switch to override the IMA (with an on/off button, not a momentary) I got an awesome amount of regen and immediate slowing action. Luckily I was smart enough to test it on back roads with no traffic.
Old 02-19-2015, 02:19 PM   #126 (permalink)
Thanks for the info.
The switch in your application will need to handle the amperage that the coil of the injector relay is pulling. This is probably around 100-150mA.
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (02-19-2015)
Old 02-22-2015, 04:54 PM   #127 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
wow, 13 pages about shifter knobs lol.
Old 02-22-2015, 05:48 PM   #128 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Tip from me:
If you're printing with ABS which I assume you are.
You know how the surface finish shows the layers and sucks? Buy some acetone and a glass jar. Put some acetone in the jar, suspend your part in the jar. But the lid on. The acetone vapors will melt the outer layer of plastic. Take the part out. Let it sit for a day. Come back and you'll have parts that look like molded plastic bits. You'll have to play with time and distance from the acetone at the bottom of the jar but I find about 10 minutes to be good. Make sure to do this under a fume hood or outside. It takes practice to get this right.
The picture is the science vehicle that my team and I designed for an international collegiate design competition that we're going to this June. Aside from the fiberglass blades, every other piece is made with printed ABS. This science vehicle withstood 26 G's and a 2 gram black power deployment charge during a rocket flight.
Anyway, 3D printing is awesome! Aside from CNC and watercutting, it's probably my favorite manufacturing technique.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
Shawn D. (02-24-2015)
Old 02-22-2015, 08:00 PM   #129 (permalink)
cowmeat's Avatar
Maverick Hybrids
Buy an Insight, you'll get it!
Old 02-23-2015, 09:39 AM   #130 (permalink)
Rat Racer
It's not about shift knobs, it's about kill switches. And any other switch you'd care to imagine, right where you already have your hand.
