05-15-2010, 10:20 PM
#11 (permalink)
Sorry for the necroposting -- this thread is exactly what I was going to ask about. I've been trying a little EOC and the FE is reported at 1,200-1,500mpg, or similar. Not the 9,999 that I get when I've downshifted.
Odd, really. If I EIC, I see something 200-350mpg, depending on the speed I am traveling. So, EOC adds a digit...
Oh I have it on Hybrid mode, FWIW.
05-16-2010, 01:11 AM
#12 (permalink)
Pokémoderator
Neil -
In EOC my MPG=10*MPH. Make sure to watch your RPM, MPH, and MPG on your instant gauge display. The ECU/PCM reports 61 RPM under EOC for me. Can you check your RPM output the next time you EOC? I want to know if it's 0 or ?!?!?!?
I get the same result regardless of hybrid/non-hybrid mode. It's not odd to me because we're operating outside of the expectations of the OBD-II protocol (GIGO).
CarloSW2
05-16-2010, 03:55 PM
#13 (permalink)
Okay, I checked today: the RPM's are 0, but the GPH is 0.02 when EOC'ing. I guess this is just a quirk with the computer on the xA?
05-16-2010, 06:10 PM
#14 (permalink)
Pokémoderator
Neil -
I would argue that it's the SG. To my knowledge the OBD-II protocol does not provide a GPH value. The GPH and MPG values are derived by the SG. I wouldn't be surprised if this is an artifact of "divide by zero" safeguards in the SG algorithm.
CarloSW2
05-16-2010, 06:56 PM
#15 (permalink)
...beats walking...
...FWIW, my 2009 Vibe with 1.8L (2ZR-FE) SIDI engine and 4-sp auto, does something similar. The SGII MPG.inst displal momentarily goes to 9999 then jumps back to a XXX.X MPG reading whenever I shift the tranny into N at highway speeds for coasting.
...the Pontiac Vibe is (was) just a Toyota Corolla Matrix with GM badge and modified external sheetmetal; SIDI = Spark Ignition Direct Injection.
...I will definitely watch during tomorrow's commute to work to see if I see the same 10-times-KPH relationship that you see.
05-19-2010, 12:40 PM
#16 (permalink)
Hypermiler
I'm pretty sure it's a quirk with how Toyota reports something or other to the OBD port. My sister's 2002 Camry reports the same 0.02 gph any time the ignition is on and the engine is off. Climb in, click to on but don't start it, and it's already reporting fuel usage.
My Civic and Odyssey, on the other hand, will both report 0 gph every time the engine is off. My mom's nissan truck as well.
06-11-2014, 05:37 PM
#17 (permalink)
Sorry to bring up an old thread.
I finally got a SGII and noticed that the SGII does not display 9999mpg while i EOC.
Is this just something i'll have to live with?
10-13-2014, 01:22 PM
#18 (permalink)
Zombie thread alert...
The 2007 Civic is doing the same thing: no 9999 mpg instant reading when the engine is killed.
I thought it might be related to keying off, so I also verified it two other ways:
1) with a kill switch on the fuel pump circuit, and,
2) by stalling the car with the clutch at the top of a hill and then letting it gather speed down the hill (instant MPG goes up as the car picks up speed).
This is with a SG2.
Have to dig a bit more...
10-21-2014, 02:36 PM
#19 (permalink)
FYI: I exchanged e-mail with the programmer at Linear Logic on this.
He suggested it might be the ECU is "stuck" on the last non-zero value it had as the engine was stopped, which the gauge is reading. So he asked me to kill the engine while in fuel cut mode with 9999 on the display.
I did, and it still didn't stay at 9999.
It seems to me a simple logic update would be: if RPM is zero, fuel use is also zero.
Will keep you posted.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
10-21-2014, 03:19 PM
#20 (permalink)
Eagerly awaiting your results!
I used to use torque app, but max mpg it would display is 255mpg, thus it cannot properly calculate eoc mpg.
Then when I switched to sg 2, I was a little disappointed that it does not correctly calculate eoc mpg as well.
