Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 01-23-2013, 11:45 AM   #361 (permalink)
Runs with scissors
Spot - '05 Scion XA
90 day: 30.33 mpg (US)
Originally Posted by t vago View Post
You'd want to ensure that the bits are all aligned along with the rotational direction. If the bits are all aligned against the rotational direction, you'll actually slow down the hard drive platters!
Easily solved with sub-equatorial magnets.
Old 01-23-2013, 03:51 PM   #362 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by MTXA View Post
I bought some magnets manufactured below the equator to install on my fuel line. While my mileage increased, my car started pulling to the left because I hadn't taken into account the opposite free electron flow in sub-equatorial valance rings. A fool and his money were soon parted.
Truly, there's nothing like going around in circles...
Old 01-23-2013, 05:24 PM   #363 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Maybe you're doing it wrong?
Project Avalon: E bike build
Old 01-24-2013, 12:25 AM   #364 (permalink)
Runs with scissors
Spot - '05 Scion XA
Shoot, no maybe about it. I got the sequencing right, but instead of using zip ties I used ten penny nails and my trusty hammer.
Old 01-24-2013, 07:11 AM   #365 (permalink)
razor02097's Avatar
Well there's your problem
It worked, the engine didn't use as much fuel but the fuel you saved leaked out where you drove in the nails
Old 01-24-2013, 08:59 AM   #366 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
check and see if you left the hammer stuck to the magnet!!!!
If so it could be draining all the 'power' into the hammer
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-24-2013, 01:02 PM   #367 (permalink)
magnets saved so much fuel,I started driving a magnet
I used so little fuel,I said,hell,I'll just get rid of the car and ride on a big magnet,so I ordered up a large magnet and a seat from the Acme company,bolted the wheels from the car onto the magnet.Works great,cost me 0 to drive.
Old 01-24-2013, 01:44 PM   #368 (permalink)
Runs with scissors
Spot - '05 Scion XA
Magnets on the fuel line makes sense since gasoline is ferrous right?
Hey, I saw that movie! Ferrous Fuellers Day Off. A real tear jerker.
Old 01-24-2013, 01:52 PM   #369 (permalink)
razor02097's Avatar
The Ferrous Ferrari Found Five Fuel Fills For Fifty Franks.
Old 01-24-2013, 02:20 PM   #370 (permalink)
Runs with scissors
Spot - '05 Scion XA
Ok, ok, enough goofing off. I am now going to move the question to my amygdala where my most powerful thoughts emanate from.
A fuel injector is an electromechanical solenoid consisting of an electromagnetically inductive coil wound around a steel pintle. When the magnetic field is energized, the pintle retracts into the body of the fuel injector allowing pressurized fuel to be sprayed into the intake system or the combustion chamber. When the injector is not energized, no fuel is used resulting in infinite MPGs. When the magnetic field is energized, fuel use increases. Therefore, the scientific mind must reasonably conclude that a magnetic field substantially increases fuel use. You can quote me on this.
The Following User Says Thank You to MTXA For This Useful Post:
mcrews (01-24-2013)
Magnetic engine returns BillWhedon The Unicorn Corral 22 03-13-2013 03:09 AM
Uk ford transit, economy increase? chipX EcoModding Central 14 10-11-2012 02:38 AM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 01:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 12:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
