Old 08-05-2008, 11:37 AM   #1 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
Auto in N question
The family and I went to see my Brother in NC this past weekend
We took the PT Crusier - auto tranny.
I did hook up the SG so i could see how we did.
I gathered data on the car at several speeds to get a feel for the impact MPH on MPG
While doing this - i also wanted to see if coasting in gear was better or worse then costing in Neutral.
From a consumptiuon point of view - coasting in N seemed to use slightly LESS fuel than coasting in gear. I suspect the PT does not have a fuel shut off as the MPG did not skyrocket.
Both cases had the instant MPG jump to about 75 ( N hit 80 a few times) hence i called it SLIGHTLY less fuel.
I wanna play with it some more and get more data - a little more contolled than "30 minutes of data crusing across SC)
Here is my observation and question.
When i shift the tranny into N - I expected the RPM to drop to Idle - which is what the Manual in my Altima does... but it did not?
going 65 mph was about 2400 rpm or so. shift to N - engine stayed near 2400 RPM ! HUH? Both the TACH and the SG said this..
the MPG did go up so i know less fuel is going IN -
Is this normal for an AUTO? Am i thinking "Manual Tranny" here?
I do not drive the Crusier much ( wifes car) so i had not played with it before. but am a little confused at this.
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 08-05-2008, 11:49 AM   #2 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Wow, that is interesting. I can only speak from my own experiences with the Scion XA (automatic) and when I go to N from 45 (since that's where I usually drive at) my RPMs take a dive from 1800-1900 down to 700-900. MPG gains are immediate (instant and current trip) but I'm trying to get into the habit of DFCO coast first then N-coast once I'm below the minimum 1200-1400 rpm to make the most out of fuel consumption.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-06-2008, 10:49 AM   #3 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
it may be an idle controler problem
Old 08-06-2008, 11:30 AM   #4 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
mine drops to idle also.
what happens if you rev the engine a little? it might not be totaly out of gear.
Old 08-06-2008, 01:44 PM   #5 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
What is the idle after it has warmed up?
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 08-06-2008, 01:50 PM   #6 (permalink)
F150 - '97 Ford F150 Lariat
Taurus - '02 Ford Taurus SE
the 73 - '73 Ford Thunderbird
the race car - '95 Ford Thunderbird LX
The Brick - '98 Buick LeSabre Limited
My wifes 02 Taurus does that as well....it seems as if speed and RPMs are in direct corelation with each other.
The more I slow down, the RPMS drop......
Old 08-06-2008, 02:52 PM   #7 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
My Jeep Cherokee works the same way. Makes the N coasting basically worthless on the Jeep. especially since it has the fuel cut off. The only difference I see is I can coast just a little bit farther. The only time I use N is when I'm sitting at a light. Drops the fuel use from 0.74gph to 0.60gph.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 08-06-2008, 10:52 PM   #8 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Within a couple seconds mine drops to 800-1000 rpm when going to N at any speed. Dont have my mpguino done yet but Im sure Im using less fuel in N as well.
Winter daily driver, parked most days right now
Summer daily driver
Old 08-07-2008, 12:25 PM   #9 (permalink)
Eco Noob
Next time i am in it i will check a few things.
warmed up idle ( Stoped in D)
warmed up idle ( Stoped in N)
Coasting in gear ( at some MPH)
Coasting in N ( at same MPH)
i will check the GPH and the RPM at those cases.
with that info I will hit the Crusier forums and see if this is common or an error
thanks for the inputs
steve
Old 08-07-2008, 09:09 PM   #10 (permalink)
A lot of this depends on the gear and control layout of the transmission.
Because there potentiall could be a big difference between the engine speed (low)and the trans output speed (high), and what gear range is selected from neutral to re-engagement.
Some control strategies will hold the engine above idle in a neutral coast to reduce trans load on re-engagement.
Design competition: hybridize the Tuk Tuk (auto Rickshaw) MetroMPG EcoModding Central 4 02-07-2009 03:23 AM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 03:07 PM
Hello...and a question! joebedford Introductions 5 06-12-2008 10:26 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
