02-23-2020, 04:34 PM
#8541 (permalink)
One might harvest melanin from black fungi that eat radiation from nuclear waste and use it to make solar photovoltaic cells that are more efficient (and insulation for aircraft and space habitations).
Not responsible for spelling until vBulletin's British-spelling leaning spell checker is fixed.
02-23-2020, 07:51 PM
#8542 (permalink)
If microbes can eat ionizing radiation seems like we could all be extraterrestrials.
02-24-2020, 01:45 PM
#8543 (permalink)
02-24-2020, 03:07 PM
#8544 (permalink)
It's corporate capitalism against the insects. Which has been around longer? Which will be extinct first?
We warm fuzzy mammals are caught in the middle.
02-26-2020, 11:58 AM
#8545 (permalink)
reasonable to state correlation is causation
Originally Posted by redneck
It may be reasonable to state,however, causation is not established.Ice-loss-induced tectonic rebound can just as easily explain accelerated fault-stress ruptures as causation for the volcanic activity,turning the table on the volcanologist.
They haven't explained Equatorial oceanic heat transport south.They haven't explained atmospheric heat transport to Antarctica.They haven't explained thermodynamic/haloclinic -induced gyres transporting heat to bottom water at the grounding line.They haven't explained albedo dynamics.They haven't explained foehn winds.They haven't explained reverse-lapse-rate,descending air mass heating at the coastline.Where's the energy balance for the ozone hole?
Is there any allowance for calibration drift on the remote-sensing satellite array,compared to,real-time, in situ measurements taken directly under the ice?When Lonnie Thompson was 'on' Mt. Kilimanjaro,taking temperature readings on the ground,space-based systems were reporting bogus temperatures for the same exact location.Can you vet the satellite data? Can Kamis walk up to space and check the satellite?
02-26-2020, 12:02 PM
#8546 (permalink)
insects
They need a lobbyist with a deep pocket.
02-26-2020, 04:45 PM
#8547 (permalink)
Oh, I must have imagined this too.
"Climate scientists say the temperature has been dropping for 30 years"
Always so dire, always so wrong.
02-27-2020, 01:01 PM
#8548 (permalink)
It is very important that this thread be kept alive
Originally Posted by [URL="https://ecomodder.com/forum/showthread.php/feminist-comes-terms-mens-rights-movement-36403-8.html#post617832"
Batman Junior[/URL]]Talked it over with Tim: the AGW thread is more than enough for hot button topics around here.
Shutting this one down... with apologies for not doing it sooner.
In that regard, and via S0, there's a review of the extent of Arctic Permafrost by the European Space Agency:
ESA - Picturing permafrost in the Arctic
Ice melt isn't the only thing freshening the Arctic Ocean
The Arctic Ocean is the smallest and shallowest of the world's five major oceans. It is also known as the coldest of all the oceans. The International Hydrographic Organization recognizes it as an ocean, although some oceanographers call it the Arctic Sea
02-27-2020, 01:16 PM
#8549 (permalink)
This is a total distortion of what science was indicating. We did have cooler than expected temperatures - and it was because we had bad particulate and smog pollution. Ironically, when we got cleaner cars, this "shading" largely went away, and the expected warming resumed.
You need to look at the total picture, and stop making a fool of yourself. Basing your claims on falsehoods prevents you from having credibility, on this.
02-27-2020, 02:25 PM
#8550 (permalink)
So, who's ahead?
According to today's S0 if we take care of waste and pollution, the climate will sort itself out. What he calls the Win-Win Scenario.
