Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-17-2014, 11:51 AM   #111 (permalink)
Most people are interested in water injection for power, though, rather than economy.
Friend just finished a build for a customer. 240+ whp out of the 2.8 liter VM Motori, with a chip, intercooler, exhaust and water injection, up from 178 whp all-stock. That's one happy motor.
Old 05-30-2014, 08:36 PM   #112 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
wrong with capital R
When you add a hydrogen cell to a vehicle the vehicle's O2 sensors sense the change and dump in more fuel to compensate to get you right back to 14:1 as it's designed.
Hydrogen burns with oxygen to form water vapour. In other words, the cars ECU will lean out the intake mixture because some of the gasoline required will be displaced with hydrogen to form the proper stoichiometric ratio. There is no oxygen "hanging out" in the exhaust when you inject hydrogen into the motor. In other words your own bogus science already is proving your philosophy wrong.
ok
so
this is NOT how it works
02 sensors do not see oxygen
so theory of hoaxes regarding extra oxygen in the exhaust causing something is complete and utter
blarney
02 sensors or more correctly Lambda sensors
see and measure the presence of
combustibles ,
any combustibles
including hydrogen
in the exhaust
so
if some pudding head is attempting to describe why HHO does not work
(in newer systems with feedback from 02 / lambda / AFR sensors)
and he or she starts talking about
lean condition caused by adding more combustibles or 02 to the equation
then that pudding head is fibbing or ignorant or
attempting to deceive the reader or audience
and Lambda or
stoich is
14.69 to 1 NOT 14 to 1
i will add none of these crack smokers have contacted myself about testing their systems
color me surprised
offer stands
thank me very much
spank you pudding heads
and
all
newer systems with AFR sensors are capable of operating in "lean burn"
or leaner than 14.69 to 1
Old 06-01-2014, 11:13 AM   #113 (permalink)
bobdbilder's Avatar
Knight - '03 Proton Waja
90 day: 37.15 mpg (US)
Whoopee - '01 Proton Wira 1.3 Aeroback
90 day: 38.69 mpg (US)
I had my fair share of experience with nay sayers. My advice is to keep hanging on. If your intent is pure and true, veils shall be set aside.
My own thoughts on this is that it is workable. But it needs a bit more work. This presumption is based on my previous work for Draeger a German company that makes gas detectors. Most of my clients are in the oil and gas business. If you are talking about misinformation, O+G is the king of propaganda. As you may well know. I can say it now coz they've kicked me out and I have no intentions of getting back in. What I have learned is that if there is too much against you; you must be doing something good.
The problem that I see is energy used for the process. If you use independent power source like a solar cell, you get HHO production even while the car sits parked under the sun. Which is ok because you do not want to produce too much because of storage issues. Hydrogen is highly combustible especially in the presence of O2 - 4%by volume in air. But it also has an upper limit of 65%by volume. That is when there is insufficient O2 to burn. You can say its 'saturated' or too rich to cause a fire. Again that's the condition in air (16% O2). No stainless steel containers as H2 tends to cause mechanical structure issues with SS in the long run. You would need measurement such as from catalytic sensor (wheatstone bridge) to stop production at a certain limit. So the sensor would be connected to a transistor or optical couplers. The amount generated is small but it is still savings. Any savings is good. Therefore, try starting from small and then build up. Kaizen.
Old 06-01-2014, 03:15 PM   #114 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
That is only the beginning of the problems. I've only heard one remotely coherent theory on it and it is still plagued with problems.
If nobody is succeeding at it then they all must be doing something wrong?
If you are thinking simple retrofit, then you are severely misguided. Just hook that solar panel up to your hybrid traction battery otherwise.
Old 06-01-2014, 03:20 PM   #115 (permalink)
either that or it's ..... Naaaaaahhhh they must be doing it wrong
Old 06-01-2014, 06:24 PM   #116 (permalink)
...beats walking...
Yeah, but if they (a) do it wrong twice or (b) do it twice as wrong...wouldn't that make it wright?
Old 06-01-2014, 07:57 PM   #117 (permalink)
bobdbilder's Avatar
There is nothing wrong in failure as long as you learn from it. You are leading on a road that nobody knows how to get there.
Old 06-01-2014, 08:53 PM   #118 (permalink)
You got that right at least.
Old 06-01-2014, 09:20 PM   #119 (permalink)
...beats walking...
Einstein's famous definition of insanity: "..doing the samething over and over again and expecting different results."
The Following User Says Thank You to gone-ot For This Useful Post:
niky (06-01-2014)
Old 06-09-2014, 05:40 PM   #120 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Unless it kills you
Case in point (where even the scam artists have turned their backs)
Explosion at California water fuel research company kills inventor
hho, hho boosters, hydrogen, hydroxy
