Old 11-30-2009, 05:12 AM   #451 (permalink)
discovery's Avatar
Ok I just finished reading the whole thread. It took me two and half days to read it from strat to end, it's like reading a novel don't want to miss anything. Now that the T.G. is over it's time to se some pic's and the progress done. Keep it flowing one of a kind, i bet it will be best in show.
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 11-30-2009, 05:16 AM   #452 (permalink)
discovery's Avatar
P.S. -Even my girl is intersted in the thread with no so whatever mechanical experience. "Hope she does not read this last sentanse"
Old 11-30-2009, 01:11 PM   #453 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
ChrisT -
Sorry for your loss , but your online support group is here for you .
SVOBoy -
Sometimes it's better to take a step back and continue when your mind clears. ChrisT is right, your ball joints are f'ed, going to have to replace them.
I am kinda sad that you haven't completed the IRX, but this saga will continue in a month, I anxiously await a climactic finish! Preferably a successful one!
American by right
Ecomodder by choice
Hypermiler by necessity
The Following User Says Thank You to Funny For This Useful Post:
Christ (11-30-2009)
Old 11-30-2009, 01:40 PM   #454 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I have a somewhat different outlook about death than most people do... So I'm not distressed about it at all. Thank you though.
SVOboy - I'm looking around, I might have a pair of ball joints I can send you, but it's not likely.
Old 11-30-2009, 08:58 PM   #455 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by SVOboy View Post
It's just a drive belt, as the insight engine uses a timing chain. Eventually I plan to go all electric with it. Do you think it's likely I can find a rando belt that will fit? There's no adjustment of the pulley, unfortunately.
If you can get a spec on the correct belt http://www.beltsforanything.com will have it.
They are local to me and I'd be happy to pick it up and donate it to the cause.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 12-01-2009, 12:32 AM   #456 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Thanks for the support folks. I'll get some specs on the belt, though I'm trying to figure out if the pulleys are different from the A/C to non-A/C models to cause the current mix up.
Topher - The ball joint will be fine if I can just get the damn thing off. It's not mangled yet. I'll try the torch when I get home.
Old 12-01-2009, 01:04 AM   #457 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Smacking the knuckle (don't miss! ) w/ a sledge hammer a few times is usually enough to get 'em to pop out. I've always had bad luck w/ boots using a pickle fork
The Following User Says Thank You to roflwaffle For This Useful Post:
Christ (12-01-2009)
Old 12-01-2009, 02:50 AM   #458 (permalink)
Ben -
Hopefully, you can make due with what you've already got... I didn't manage to find any good ball joints for you. I do know that if you happen to need them new, they're inside the $20 threshold.
Old 12-01-2009, 11:19 AM   #459 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
you don't have to stress over Honda ball joints or use a sledge hammer. pick up one of these on you way back.
KD Tools Universal Tie Rod End Remover
I have used mine to remove many stubborn and mangled Honda ball joints and rod ends.
A must have tool.
Old 12-02-2009, 02:33 AM   #460 (permalink)
Dartmouth 2010
SVOboy's Avatar
Thanks for the help and the link to the tool. I will have a bit more time once I return home, so I've got this plan:
I'll just stick the knuckle with the LCA on the car, then use the ball joint trick I usually use to pop it, then go ahead and swap out the LCA. Hopefully this will work and result in a decent joint and the ability to replace my boot.
The Following User Says Thank You to SVOboy For This Useful Post:
aerohead (12-02-2009)
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
