09-19-2019, 03:58 PM | #6928 (permalink) |
Intelligible at 1.75x. The train analogy at 11:21 is a good one.
Acceleration is a change in velocity, surge is a change in acceleration. Whatever will be, will be. The best strategy would be designed-in resilience. Like a solar-powered semi-submergible hausboot.
. .Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster ____________________ . .Two wrongs don't make a right, but three lefts do. |
09-19-2019, 04:53 PM | #6929 (permalink) |
Sub - '84 Chevy Diesel Suburban C10 SUV 90 day: 19.5 mpg (US) camaro - '85 Chevy Camaro Z28 Riot - '03 Kia Rio POS Team Hyundai 90 day: 30.21 mpg (US) Bug - '01 VW Beetle GLSturbo 90 day: 26.43 mpg (US) Sub2500 - '86 GMC Suburban C2500 90 day: 11.95 mpg (US) Snow flake - '11 Nissan Leaf SL SUV 90 day: 141.63 mpg (US) Thanks: 270
The cult of climatology should be able to answer questions 3.
1 what kind of electric car do you drive? 2 how much solar do you own? 3 do you live at or below sea level? The correct answer is equally to or greater than 50 feet. A negative answer renders the previous 2 questions null. If they answer all 3 incorrectly then they are nothing more than completely bs filled virtue signalers. If they can answer all 3 correctly then you know they can at least smoke what they sell.
1984 chevy suburban, custom made 6.5L diesel turbocharged with a Garrett T76 and Holset HE351VE, 22:1 compression 13psi of intercooled boost. 1989 firebird mostly stock. Aside from the 6-speed manual trans, corvette gen 5 front brakes, 1LE drive shaft, 4th Gen disc brake fbody rear end. 2011 leaf SL, white, portable 240v CHAdeMO, trailer hitch, new batt as of 2014. |
09-19-2019, 06:39 PM | #6930 (permalink) |
Electric boats?
