01-15-2010, 04:21 PM
#61 (permalink)
Pokémoderator
Hello -
Found a nice turtle to follow on the 710 South today :
Code:
ROUTE : 10 West -> 710 South -> 105 West -> 405 South -> Exit Freeway
=> Roughly 27+ miles
NET ELEVATION CHANGE : ~210 feet drop
SCANGAUGE "CURRENT" READINGS :
61.1 MPG,
0.4 Gallons,
207 Water Temp Max,
27.7 Miles,
2473 RPM Max,
0.5 Hours,
65 MPH Max,
48 MPH AVG
IAT READING : Forgot to look! Probably in excess of 125 degrees F.
WEATHER(.com) :
70.5 degrees F,
Partly Cloudy,
17.5% Humidity,
24.0 degrees F Dew Point,
30.17 in. Pressure,
TIME : ~11:50 AM to ~12:20 PM, ~30 minutes
RECENT CAR CHANGES : Nothing worth mentioning ... yet
HYPOTHESIS :
Look at the low humidity and dew point.
Just a warm dry day in LA
CarloSW2
01-15-2010, 08:20 PM
#62 (permalink)
Tank - '76 Chevy El Camino Classic 90 day: 25.89 mpg (US) Sabrina - '91 Mercedes Benz 190 E 90 day: 37.07 mpg (US) Angel - '88 Mercedes-Benz 420SEL Last 3: 23.01 mpg (US) Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
I've been dricing the last two days in my mom's mercedes and i was suuper proud of myself I got 35.6 MPG IN the city I just kept below 40 MPH the whole time and it was easy
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
01-15-2010, 08:44 PM
#63 (permalink)
Pokémoderator
Domman56 -
Wow, did you have any "magic streetlight" runs where you just kept rolling through the greens? Last week we were on Ventura and it seemed like we went 5 miles without hitting a red light. Probably only 3, but it *felt* like 5.
CarloSW2
01-16-2010, 12:49 AM
#64 (permalink)
Originally Posted by cfg83
Domman56 -
CarloSW2
Very few But taking backstreets helps because you can do california rolling stops through the stopsigns
Tank:
01-19-2010, 03:28 PM
#65 (permalink)
Pokémoderator
Hello -
Raining today. Here's the view on the 105 West :
Code:
54.4 MPG,
0.5 Gallons,
206 Water Temp Max,
27.6 Miles,
2086 RPM Max,
0.6 Hours,
60 MPH Max,
45 MPH AVG
IAT READING : Forgot to look! Probably in excess of 115 degrees F.
WEATHER(.com) :
55 degrees F,
Rain,
80% Humidity,
49 degrees F Dew Point,
29.64 in. Pressure,
TIME : ~10:55 AM to ~11:30 PM, ~36 minutes
RECENT CAR CHANGES : None
HYPOTHESIS :
None. Just wanted to capture a rainy day.
Given the situation, I'm happy with the results.
CarloSW2
01-19-2010, 05:07 PM
#66 (permalink)
Left Lane Ecodriver
I drove 30mi south, into some gentle hills, on the throughway. I got 68mpg on the way there, going 62-64mph the whole way, and lean burning most of the way. 65mpg on the ride home, despite the descent, because I drove 74mph for the first third of the way, forfeiting lean burn.
I'm very happy with both numbers. If I had my summer tires on, it would have been 70-something mpg, plus the lean burn window would be wider.
01-29-2010, 06:30 PM
#67 (permalink)
Left Lane Ecodriver
6°F = a hard earned 50.2mpg today. Almost no lean burn or regenerative braking.
02-16-2010, 02:54 PM
#68 (permalink)
Pokémoderator
64.9 mpg
Hello -
Very good day on the way to work :
Code:
ROUTE :
64.9 MPG,
0.4 Gallons,
206 Water Temp Max,
27.5 Miles,
1986 RPM Max,
0.6 Hours,
58 MPH Max,
45 MPH AVG
IAT READING : Hot Air Intake led to Input Air Temp readings of
around 120+ degrees F.
WEATHER(.com) :
78 degrees F,
Sunny/Fair
22.5% Humidity,
37.5 degrees F Dew Point,
30.00 in. Pressure,
TIME : ~10:40 AM to ~11:15 AM, ~36 minutes
RECENT CAR CHANGES : 3 of four wheels covered in plastic racing disks.
No rear wheel skirt. Side skirts and spring-loaded front air dam in place
but not video-tested.
HYPOTHESIS : Warms days + slow traffic. Very low humidity. It's amazing to think I could have got my record today in "warm but not hot" weather.
CarloSW2
02-16-2010, 07:00 PM
#69 (permalink)
Nice work. Warm weather is still a distant hope here!
02-16-2010, 08:03 PM
#70 (permalink)
I believe my Tempo has a 12 gallon or so tank. Today, I switched my air filter out for the old paper filter. At first, the engine quit a few times because the ECU didn't fully recalibrate, but it was okay after. A little less power, though. The weather was a LOT friendlier than it has been, with no rain all day and a sunny, low 50's afternoon.
The car seemed to run a little warmer this morning, but the needle moved just over halfway between hashmarks. Since there are 6 hash marks, that would lead one to believe that each mark is 2 gallons. If that was true, I would have gotten almost 40 MPG today. However, taking into account the past E and F capacity, I may have hit my goal of 30 MPG. I'll see what the final calculations are after this tank is used up.
In Reason we Trust
