Old 11-25-2009, 12:13 AM   #61 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
so how much are the digital gauges your using? Is there a vac gauge that works with a PDA? I would love to mount a Zodiac to my dash and have multiple displays for different things.
Old 12-05-2009, 11:21 PM   #62 (permalink)
I would appreciate some help for anyone who might know about this situation.
I recently bought a new Chevy Aveo for my wife (1.6 'EcoTec' engine). She tends to drive with a somewhat heavy foot, so I want to install a vacuum gauge in it. I looked everywhere in the engine compartment and I cannot find a single vacuum line to tee into! (I've installed vacuum gauges on other cars in the past and I know what vac lines typically look like - but here I see nothing, zip, zero, nada. I know better than to tap into the brake booster line.
Anybody here work for Chevy? Anyone familiar with this new engine setup?
Old 12-05-2009, 11:22 PM   #63 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Interessant. I have the 2.2L Ecotec, but I never actually looked to see if it had vacuum lines. I'll have to go look in the morning.
Old 12-06-2009, 12:25 AM   #64 (permalink)
Grrr :-)
Nerys's Avatar
its an aveo? that means its ODBII since there were no aveo pre 1996.
just plug an odb fuel meter into it. you can get them on ebay pretty cheap I think.
Old 12-06-2009, 01:01 AM   #65 (permalink)
Pardon my ignorance (I'm 'on the wrong side of fifty' and can remember owning cars with distributors that had points). I know what OBD is - but why are there no vacuum lines? Also, what will a "fuel meter" read? - and how does it compare with the readings of a vacuum gauge?
Old 12-06-2009, 01:57 AM   #66 (permalink)
Grrr :-)
Nerys's Avatar
I don't know really but I know the data coming from the computer via the OBD interface can be used to calculate fuel economy. Hmm scanners are cheao but not sure if any of them will read out vaccum similar data.
as to why no vaccum? no idea :-)
Old 12-07-2009, 10:22 PM   #67 (permalink)
...beats walking...
...if you get too much "needle oscillation" at idle, you can install a "restrictor" (also called 'vacuum arrester') in the vacuum line which should dampen the needle movement.
...the "restrictor" can be just a small piece of smaller diameter tubing (thus a smaller inside diameter) inserted at the "vacuum source" end.
Old 12-08-2009, 02:23 PM   #68 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Doesn't needle oscillation indicate compression problems?
Old 12-08-2009, 02:44 PM   #69 (permalink)
...beats walking...
...yes and no, or simply: not always.
...if the oscillation "coincides" with the cylinders, then the answer is probalby yes, there's likely a compression problem. But, then again, it might also be: (a) vacuum gauge diagrapham sympathetically vibrating, or (b) 3 or 4 cylinder engine at low rpms, so there's a big "gully" in the vacuum level as each cylinder sucks air from the intake manifold...almost like "ripples" in the vacuum. That's why I suggested the restrictor...a first step toward diagnosis of "what's causing" the oscillation.
...if we were talking 6's or V8's I'd agree 100% on "problem" but things get 'interesting' on the smaller engines...especially a 3 cylinder!
Old 12-08-2009, 09:04 PM   #70 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I worked on an Aveo before, but I don't remember even seeing any vacuum lines? I bet the one from the brake booster would work, but you would have to tap in close to the engine as possible for a good source.
GeoMetroforum.com - got mpg?
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Fuel Gauge Quirk 2001Jeep General Efficiency Discussion 6 06-20-2008 02:20 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
