Old 10-13-2008, 10:56 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Hybridizing a 2-wheel drive pickup
Hey folks,
There has been some discussion before on this forum about building a hybrid by taking a 2-wheel (front-wheel) drive car, which also had an all-wheel drive version, getting the back axel from the all-wheel, bolting that on, adding a motor, and making a hybrid from it.
I think it's a pretty cool idea.
Also, small pickup trucks make great EV's because they already have the frame and suspension for the battery system.
I was wondering, would it be possible to take a rear-wheel drive truck, put in a front axel from an 4-wheel drive version, put a motor on that, and make it into a hybrid?
I have no idea what this would take. I know nothing about 4-wheel drive trucks, so please tell me to stop fantasizing right now if it's a stupid idea.
Right now, my gas truck is a 1995 Chevy S10 4-cylinder, 5 speed. There is lots of room to work under the hood, because everything else is the same size, but the engine is smaller.
I was just thinking that I already have a truck and it's rear-wheel drive. I already have a full EV (Geo Metro and a motorcycle).
I would just love to get some better fuel economy on the long haul, and maybe I could do it by using electric in town, and save the gas for the highway.
I already know about all the things that need to be a little different for an EV mode, such as having a large vacuum resevoir for the power brakes.
Maybe building myself a hybrid isn't in the so distant future?.....
Anyways, dumb idea or or possible to reasonably do? Like I said, I really don't know anything about 4-wheel drive.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-13-2008, 11:14 PM   #2 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Sounds like a great project. Overspeeding is an issue, so you'll want to make sure you get a diff ratio that keeps the motor under its redline at any speed your truck will ever travel. You could probably also adapt one of those "2-speed" rear ends to the front if you want a couple of gear ranges, or even go with a full transmission. (Some Corvettes use a rear-mounted tranny, so if you're short on space up front, you could put the tranny in back and run the driveshaft up to the front diff.)
I'd avoid using a transfer case, since I've heard that they're very inefficient compared to a transmission.
It's hard to swing a large enough EV motor with regen without going to AC (more expensive), but you could then use your deceleration to charge up the batteries--even when you're running on the freeway with the gas motor.
Old 10-14-2008, 12:07 AM   #3 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
yeah, I figured it would be easiest to completely do without any transfer case, and like you said, just need to watch the overspeeding.
Can anyone tell me how much a 2-wheel and 4-wheel drive version of a truck have in common? Would a front axel from a four-wheel pretty much "drop-in" to a two-wheel bay?
I would imagine all the wheel/axel work could be done without having to pull the engine.
The steering would need to be disconnected, so maybe a swap to manual steering could happen at the same time.
My YouTube Videos
Old 10-14-2008, 11:08 AM   #4 (permalink)
90 day: 51.82 mpg (US)
Isn't the simplest approach to install a motor inline with the drive shaft?
That's how NetGain is doing it with their commercial system.
I think this is a NetGain installer:
Old 10-14-2008, 11:10 AM   #5 (permalink)
Of course you could control the motor yourself (instead of the OBD connection and software control that kit has), and shift to N with the ICE off for electric only propulsion.
Old 10-14-2008, 11:53 AM   #6 (permalink)
Daily Driver - '01 Ford Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
i've been thinking about this same subject for a while now.
here are 2 ideas i've been thinking about (both with manual transmission)....
keeping 2wd:
-mount some heavy-duty sprockets between transmission output and rear driveshaft.
-chain drive to an electric motor sitting either beside the transmission, or in the bed.
-need a "sprag clutch" or something similar, so the electric motor doesn't spin all the time (unless you want it to, this part is unfamiliar territory for me)
4x4 swap:
-some vehicles (like my explorer) have all the brackets ready for 4x4 hardware (to save assembly line costs i assume). find a rig like yours, but 4x4, in a junkyard and grab a tape measure
-install front axle and driveshaft only, no transfer case.
-instead of a transfer case, the front driveshaft connects to your electric motor.
with both setups, my idea is to use electric only (ICE off) for up to a "target speed", say 35 mph. then shift to start gas motor if going faster than that. I like the motor inline with the driveshaft in the video posted above, wonder how that works.
My Intro
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
2005 Honda CRV All wheel drive Salsaman55 Forum News & Feedback 2 09-24-2008 04:59 AM
Are four wheel drive vehicles better because they're safer? diesel_john Off-Topic Tech 53 05-17-2008 09:35 PM
Are 4 wheel drive passenger vehicles wasting precious resources? diesel_john General Efficiency Discussion 62 04-22-2008 01:29 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
