Old 08-30-2009, 04:50 PM   #11 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Originally Posted by droptail View Post
roflwaffle, thanks for the link and input. I will read it and check back.
Guys, the thread is about installing an electric motor inline to a (truck) driveshaft.
Geo comments don't belong here.
Thanks
What does it matter if it's a truck or a geo if the concept is the same?
The Following User Says Thank You to SVOboy For This Useful Post:
MadisonMPG (08-30-2009)
Old 08-30-2009, 05:21 PM   #12 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
I edited my posts, you can carry on.
Old 08-30-2009, 11:14 PM   #13 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Meh, installing it in between the transmission output shaft and wheels, be it on a CV or a driveshaft, isn't a huge difference. Actually, coupling it to the output shaft instead of inline can be a lot more useful in terms of the available power at whatever speed. An inline motor will have the same gearing as the rear end, which means it probably won't develop decent power until high speeds, ~40-65mph depending on the gearing, which kinda offsets it's usefulness at replacing low load/low speed/low efficiency engine operation. Coupling it to the output shaft lets us optimize power output and motor efficiency via gearing, but it's also more complex.
Old 08-30-2009, 11:20 PM   #14 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Netgain has some double-ended shafts specifically designed EXACTLY for adding in-line with a truck rear driveshaft.
They even have a black box (the EMIS) that connects to your OBDII that will control the motor added to an automatic transmission truck to make it into a hybrid.
Check out their motors and the EMIS at their web page:
TransWarP Motor Information
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 08-31-2009, 01:45 AM   #15 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
there was a thread not too long ago, someone wanted to couple a motor to the front driveshaft of the 4WD transfer case. It would work just fine. Many enthusiasts have driven home as FWD trucks, so the strength and drive-ability is there. Your truck is 4WD, so that would work, but you'd be limited to 2WD from then on, not something I could give up. But you're from So-Cal? Do you use the 4WD for offroading?
Old 08-31-2009, 10:04 AM   #16 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
do some checking on the Future Truck Competition, some of the teams that have won did motors inline with the drive shaft, a team from Madison WI a few years back got 55mpg out of a Ford Explorer and the rules of of the competition give you more points for using off the shelf parts instead of custom made parts.
I wonder if there is room to do a chain drive between the motor and the drive shaft.
Old 08-31-2009, 11:01 AM   #17 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
There's usually a fair amount of space between the bed and drive shaft, but surely not enough to put in a 9" WarP or anything like that.
The other problem you'd face there is with suspension. You'd have to have a 2-piece driveshaft, with one piece being hung to the frame so that it didn't move with the suspension, to keep the chain from binding/skipping.
Old 08-31-2009, 11:41 AM   #18 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I was throwing around some ideas with with the guys a while back about doing a hybrid pickup truck.
One idea involved a motor or engine in the BED of the truck with a chain or belt running down to the driveshaft.
My YouTube Videos
Old 08-31-2009, 04:41 PM   #19 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
CR-EX - '12 Honda CR-Z EX
Send a message via Yahoo to bluetwo
I'm surprised on one mentioned Mikes Insight with the fifth wheel.
Mikes Insight - MIMA Honda Insight Modified Integrated Motor Assist
It's written so anyone can understand it so be patient. There's a LOT of good info there. Check out the link below too while you're at it.... in fact you might want to read it first.
http://www.99mpg.com/Projectcars/ewheelforanyvehicl
Old 08-31-2009, 05:08 PM   #20 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
I'd say this is pretty much what you're looking at. He has a full-size Chevy truck, so the motor would probably clear the bed (or at worst, maybe he'd have to put a little hump in the bed over the motor), and beyond that, it's a question of turning the driveshaft into two driveshafts with the motor between and the various ends hung so they're at the correct angles.
As far as freewheeling the motor when it's not being used, I remember from the EVDL that there's no problem doing this as long as you don't overspeed it. You can check with Jim Husted on the EVDL, but I'm pretty sure that the shafts on the ADC can handle the torque from the engine.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Motor probs - commutacar electrique Forum News & Feedback 7 09-11-2009 02:14 AM
Motor Brush Advance TomEV Fossil Fuel Free 19 05-07-2009 11:50 PM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
