Old 07-03-2012, 11:03 PM   #91 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by JethroBodine View Post
Turns out, the diesel engine is lighter than the gasser. The front of the car is about an inch and a half higher than before. A guy at work brought it up today. I thought it was just me. Guess I'll have to get some new coils when I replace the struts.
Very nice opportunity to lower the car and reduce frontal area. Maybe you should just cut the existing coils first, and if the cutting does not work you can always turn around and buy aftermarket coils. You could save mucho money this way, no?
Old 07-03-2012, 11:18 PM   #92 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Cutting would be quick and easy( and probably what will happen), but I'm going to see if I can get all new parts with about a 2-3 inch drop.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 07-06-2012, 08:04 PM   #93 (permalink)
Diesel
Vacation time has been approved! Now I just have the minor detail of having the car running. Much work this weekend.
Boat tail project
Old 07-06-2012, 08:31 PM   #94 (permalink)
Cyborg ECU
If I was within 100 miles of you, I'd come help.
Old 07-06-2012, 09:19 PM   #95 (permalink)
Diesel
Thanks. I'd take you up on it.
You decided about going?
Boat tail project
Old 07-07-2012, 01:25 PM   #96 (permalink)
Cyborg ECU
The weekend portion of the Sept 8-11 is easier than the Mon/Tues part, but I might be able to swing the whole thing. If I can't, which part of that four day spread is your run?
Old 07-07-2012, 03:12 PM   #97 (permalink)
which part
The USFRA is allowing a minimum of 4-runs for each 130-Club member and I believe that racing will begin on the 1st day of Sept.8th after the driver's safety meeting and any 'handling runs' are accomplished.So it could work out at 1-run/day.
Old 07-07-2012, 08:04 PM   #98 (permalink)
Diesel
My plan is to get there on Friday, make as many runs as I can( never been and don't know if you can just get right back in line or not) and leave first thing Monday morning.
Got a lot accomplished today. Drained the gas( Pathfinder said thanks), removed gas tank, changed over some plumbing and put all new clamps on hoses, replaced hoses as necessary, installed diesel tank, and plumbed up to the filter. Still need to mount/plumb the filter housing and plumb the pump on the fuel side of things. A friend has a diesel Golf, so I tested how the shut off solenoid was wired. Power for running, no power=no run. Easy kill switch wiring.
Diesel tank in the foreground, almost ready to go in.
Tank out makes a good view of any rust hiding above the tank. It also shows that new straps are in order soon.
Sure is nice having an access hole just over the fuel tank plumbing.
More tomorrow.
Boat tail project
Old 07-07-2012, 10:48 PM   #99 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
it looks like you spent a busy shade tree Saturday
same here.
The Following User Says Thank You to Weather Spotter For This Useful Post:
JethroBodine (07-07-2012)
Old 07-07-2012, 11:05 PM   #100 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Can you guys post video of the run ?
It will be interesting seeing how the dust reacts at the rear of the car !
