Old 02-15-2011, 12:52 PM   #151 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I set my record distance tank earlier this month - 1000 km on 10.563 gal., averaging 58.84 mpg, in my xB. That's winter driving, running around to do grocery shopping, Home Depot visits, medical appts, etc. 1000 km. is 621.37 miles. I tanked up at 621.6 miles.
My biggest change was slowing down for much of this tank.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 02-15-2011, 05:00 PM   #152 (permalink)
Got a crappy 17MPG average driving to school which is 3.4 miles round trip. The next 3 days I'll be biking because the weather is great.
Old 02-15-2011, 05:45 PM   #153 (permalink)
RSX2fast4mpg - '02 Acura RSX Type S
90 day: 38.22 mpg (US)
bubbatrucker - '98 Chevrolet K1500
90 day: 18.1 mpg (US)
Congrats!
I'm not sure we both have the same definition or experience of winter, but kudos on blowing the EPA away with a vehicle that looks like it has the aerodynamics of a brick.
Old 02-15-2011, 10:25 PM   #154 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
Originally Posted by euromodder View Post
It doesn't feel natural when you're used to using engine braking / DFCO.
Yeah, it definitely felt different. I glanced at my tach, and it was around 900 rpm.
Normally 35mph would put me at the low end of 4th (probably 1600rpm) or maybe 2100 or so in 3rd.
I decided that my new goal is going to be 24mpg - the EPA highway rating -this spring (or maybe summer) with my around town commute. Last summer 22.6 - 23.5 was my general range.
With 100lbs of sand in the bed and the cold weather, 21 is realistic right now and 22 is possible.
Old 02-15-2011, 10:31 PM   #155 (permalink)
Pishtaco
SentraSE-R's Avatar
I know what winter is, having lived in AK, CO, and UT for 15 years. I have to admit CA winters are ridiculously mild. But if I can average 58.84 mpg now, I might be able to push 70 mpg in the Summer, and that would put a 750 mile tank into the realm of possibility.
Darrell
Old 02-16-2011, 04:45 PM   #156 (permalink)
dude...wait...what?
Odin's Avatar
Diesel Rx-7 - '82 Mazda Rx-7 GSL
merc 300d - '82 Mercedes-benz 300d dt
b2200 diesel - '84 Mazda b2200 D
you'd think calli's hot hot air in the summer would destroy your mpg
Old 02-24-2011, 04:53 PM   #157 (permalink)
The PRC.
I had to risk my tank this PM as A. Jnr was late for his rock star training (guitar) so I had to cruise in the right hand (i.e. 'outside' in the correct side of the road world) lane instead of my usual trundle in the left.
And damn me if Helga didn't average more than she does at dawdle ? I 'harried' a dawdling BMW out of the way (empty left lane, move over you prat) and undertook a Mini Cooper S (you don't move, I go anyway - yeah turbo, eat soot).
By the time I turned off she was showing 68 mpg AVG compared to normally 65 at dawdle. Another benefit was that the lights were out on the junction so it was a normal roundabout.
Guess what ?
Traffic FLOWED BETTER.
EDIT - this was BEFORE I picked up Jnr. I don't bully or undertake when carrying Jnr. For a start there is the swearing to explain...
Old 02-24-2011, 06:31 PM   #158 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
My car got stuck in traffic today. I had the engine off at a stoplight to save gas. As the cross-light went yellow, I turned the ignition. There was no sound of the starter turning over. I set the emergency lights, got out of the car, and pulled the big 30 Amp "IGN" fuse in the fuse box in the engine bay. The fuse was good so I put it back in. After that the starter turned over and has been fine ever since. This makes me think it could be a wiring or ignition key/lock assembly problem. Maybe rats nibbled the wiring (it's happened before). It was as if I had not depressed the clutch, so maybe the clutch ignition safety circuit is failing.
I'm taking it for service on Friday, so hopefully they will find something wrong that they can fix. If they can't find anything wrong, then I will worry about turning off the engine at lights.
CarloSW2
American Solar Energy Society
Old 02-25-2011, 02:11 AM   #159 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
Carlo, Check your connections to both the starter and the ground to the block as well as frame. Being on the left cost you don't get the issues i get in Jersey with salt air and temp expansion terminal ends and corrosion is a problem if not maintained.
What you described is common had it happen to my truck once this year and my neighbor asked me for help his terminals were loose and a friend was stuck they had a lot of corrosion. I hope it is that easy of a fix for ya.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
The Following User Says Thank You to NHRABill For This Useful Post:
cfg83 (02-25-2011)
Old 02-26-2011, 10:11 AM   #160 (permalink)
Whew, my mpg is back into the realm of reasonable. After one bad tank I just pulled off a 38mpg tank thanks to less snow and somewhat better temperatures. I can't wait for this winter to be over and new summer tires... I also can't wait until the ground thaws so I can get my garden going again. I'm looking at three boxes of seeds ready to go in the ground.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Tips to Improve Your Gas Mileage on the Highway SVOboy EcoModder Blog Discussion 1 04-01-2009 01:35 AM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
Why my gas mileage sucks. Big time. Peakster The Lounge 4 01-01-2008 04:38 AM
