Old 09-26-2012, 08:56 PM   #5861 (permalink)
PLUGnGO
jedsmd's Avatar
Originally Posted by Crossdan View Post
I have another question about the pre-charge connection. After the pre-set time I get the 12volts between the +12v and middle terminal of J1. However when I attach a relay it won't pull down. I eliminated all wiring thinking the resistance was too high and jumpered directly to a small pcb mountable relay. Still no luck. Anybody have any ideas?
Thank,
Dan
Crossdan
Shouldn't the 12 volts be measured between the middle terminal and ground?
12v measured between +12 and contactor would indicate that the contactor pin was low and had not turned on.
Jerald
Old 09-26-2012, 09:44 PM   #5862 (permalink)
Paul,
No worries. I'm already ahead of the game by having a controller that I can replace components on (assuming they're bad).
Just to make sure I don't have bigger problems, after the pre-charge timer expires I should record 12 volts between the +12v and the contactor, correct?
Jerald,
At no time, either before or after the pre-charge timer expires do I get 12 volts across the contactor (middle) terminal and ground. I'm hoping Paul doesn't tell me I have bigger problems.
I have my car on jacks waiting for the controller to spin the wheels. I'll try to install this weekend with a 24 v pack to test the motor control portion of the OpenRevolt. If that doesnt work then i definitely have bigger issues.
Dan
Old 09-26-2012, 10:09 PM   #5863 (permalink)
PLUGnGO
jedsmd's Avatar
Paul,
Jerald,
Dan
CrossDan
I think there is a software switch that needs to be set before the contactor will work. Other people have written about having problems with it. Hopefully someone more familiar will chime in....
Jerald
Old 09-26-2012, 11:48 PM   #5864 (permalink)
PaulH
MPaulHolmes's Avatar
oohh!!! Could that be what it is? Have you reprogrammed the precharge time? The default is "disabled". You would have to type something like this while the serial communications is going:
pc-time 80
save
That would set the precharge time to 8.0 seconds. Then the yellow wire would go from 0v to 12v after 8 seconds.
kits and boards
Old 09-27-2012, 05:55 PM   #5865 (permalink)
Sorry, maybe i confused things. I HAVE programmed the pre-charge. After 8 seconds it goes from 0 to 12 volts.
The question is:
Should the 12 volts come from contactor (middle) terminal and ground.
Or from contactor (middle) terminal and +12v supply. (this where I'm getting the 12v)
I just don't get enough amps to pull down the relay.
Dan
Old 09-27-2012, 05:57 PM   #5866 (permalink)
Or, to put it more simply.
Do I hook up my relay to the yellow and red wires or yellow and black wires?
Old 09-27-2012, 06:07 PM   #5867 (permalink)
PaulH
yellow to black
kits and boards
Old 09-27-2012, 09:40 PM   #5868 (permalink)
I only get the 12 volts from yellow to red.
Think I may need to start with replacing the P channel Mosfet and Optocoupler.
Old 09-27-2012, 11:27 PM   #5869 (permalink)
PLUGnGO
jedsmd's Avatar
Dan
Are you measuring the 12volts between the yellow wire and the red wire before the 8 seconds? after the 8 seconds? or both?
Jerald
Old 09-30-2012, 03:44 AM   #5870 (permalink)
PaulH
I had put a controller together for a guy over a year ago for the 24 hours of LeMons (lemons, like junky cars). It's the first ever electric that they have ever done. It's on a real life racetrack with people in the stands and everything! He just took it for a maiden voyage tonight. Nothing blew up!
There's an update at the bottom of this page here:
Got the Go-ahead from HQ for my IoE idea (Page 10)
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
raszpel (09-30-2012)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
