Old 12-09-2009, 12:42 PM   #2721 (permalink)
jackbauer's Avatar
Thanks adam. Does the iphone not run osx?
edit: got something:
http://devdot.wikispaces.com/Iphone+...+Port+Tutorial
Old 12-09-2009, 12:47 PM   #2722 (permalink)
Out of my mind, back in 5
Eh... Nope... It runs an entirely own OS... With it's own set of rules from Apple on what they allow you to do and not...
As said, they really don't want you to use the bluetooth or serial communication or any of the other fun stuff... So that's not in the Apple dev-kit...
Doesn't mean you can't get to it though... Just means you need the iPhone to be jailbroken to run the code...
Old 12-09-2009, 12:54 PM   #2723 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I've been through all this with the mpguino, when apple starts paying me to deal with their crap I will consider it
Old 12-09-2009, 01:02 PM   #2724 (permalink)
jackbauer's Avatar
ah ok my bad Don't have a problem with the jailbreak! I was never big on buying a product then being told what i can or can't do with it! Anyway back on message I built up another control board using bits i had myself and could source locally and seems to be ok with initial tests. Sadly the only part i could not source was the common mode input choke so i've linked it out for now. For anyone interested here is a list of stock numbers for some of the parts i used from Radionics (Welcome to Radionics On-line)
197-4069 1 €7.71 €7.71 28 way turned pin DIL socket,0.3in pitch
365-4155 1 €1.82 €1.82 NHG min Al electrolytic cap,470uF 25V
449-1006 1 €0.92 €0.92 FC radial elec cap,10uF 25V
538-1483 1 €0.93 €0.93 Radial X7R ceramic cap,22nF 100V 5mm
538-1916 1 €2.14 €2.14 T350 radial tantalum capacitor,16V,4.7uF
642-4547 1 €4.44 €4.44 HIN202CPZ
654-7628 1 €1.60 €1.60 20V Zener diode,1N5357BRLG 5W
I could not source the transorbs so substituted some 20v 5w zeners. Nasty i know
528-8536 1 €1.97 €1.97 Miniature NTC S861 thermistor,10k
661-9798 5 €0.45 €2.23 V-Ref Precision 2.5V 10mA 3-Pin TO-92
This is pin compatible with the specified device.
625-8665 3 €0.36 €1.08 Opto-isolator,2500V DIP4,TLP521-1(A,F,T)
Pin compatible.
466-7067 1 €24.15 €24.15 TEL5 DC-DC converter,9-18Vin 12V 6W
Pin compatible.
169-6012 2 €0.46 €0.92 Quad 2 i/p NAND gate, 74HC00N DIP14
661-3160 1 €2.77 €2.77 MOSFET DRVR 9A Single Lo Side Inv 8-Pin
Pin compatible.
810-239 3 €0.13 €0.39 Dual comparator,LM393P 1.3ns DIP8
522-2766 1 €0.79 €0.79 3386P top adj cermet trimmer,500R 10mm
214-0734 1 €2.43 €2.43 ROX1S metal oxide film resistor,1R0 1W
294-328 1 €1.55 €1.55 PNP transistor,2N3906 0.2A
672-0218 5 €0.38 €1.90 Crystal,16.000MHz HC49U
Hope this helps. I have not included resistors or basic caps as they are standard.
Old 12-09-2009, 01:26 PM   #2725 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Originally Posted by jackbauer View Post
.... I built up another control board using bits i had myself and could source locally and seems to be ok with initial tests. Sadly the only part i could not source was the common mode input choke so i've linked it out for now. For anyone interested here is a list of stock numbers for some of the parts i used from Radionics .......
A probably stupid question but, why there is a vacancy in that 8 pin IC?
Is this Paul's second controller PCB version?
Old 12-09-2009, 01:28 PM   #2726 (permalink)
jackbauer's Avatar
I think its the 2c version. I'm just waiting on the mosfet driver they were out of stock
Old 12-09-2009, 01:52 PM   #2727 (permalink)
Hello Adamj12b
I went to Wiki to copy and paste the version of software into AVRStudio, so when I compile I get a error complaining that the autocrc.h is missing.
I can not find it any where, am I doing something wrong here.
Cheers
Jeff
Old 12-11-2009, 05:05 PM   #2728 (permalink)
The $500 Electric Car
vpoppv's Avatar
Paul,
Though my wife gave me some strange looks when I opened the box and syringes popped out, the parts were so beautiful and shiny that she asked me if I was going to put them under my pillow tonight.....and I just might
And, I got enough packing material to last me a decade!! AND, it was super, super fast!! YOU ROCK!!!!
Old 12-11-2009, 05:13 PM   #2729 (permalink)
PaulH
MPaulHolmes's Avatar
Sabrina packed it! She's really really thorough. hehe.
Hey! they have the mosfet driver in stock! Don't pin that one on me, man! hahaha.
Digi-Key - 576-1209-ND (Manufacturer - MIC4451YN)
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
deodeo (03-22-2012)
Old 12-11-2009, 06:23 PM   #2730 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
A couple of days ago was our first big snow storm of the year.
It was only about 5 inches, but real heavy, wet stuff, which of course, all turned to ice.
It's also the first time I have driven my car in snow with the Re-Volt controller instead of the Curtis.
Most of the roads are pretty good, but there are still a few icy spots, including in my driveway, in town, and the middle of a few intersections.
I noticed the first time that my front tires lost traction with the road, that they spin up differently than they did with the Curtis.
Because of the "throttle-ramp-up" feature of the controller to limit amps on acceleration, the tires kinda spin funny. It's really hard to describe. I almost didn't realize what was happening at first.
Also, without a tachometer, or engine noise, it's pretty hard to notice that your motor just spun up really fast. Since the tires are just slipping, there's not much load to be reported by the ammeter either!.
Anyways, just wanted to let anyone else running around in the snow with the homebuilt controller to just to know about it.
I will try to give a better report next time I am out driving in the great white slippery-ness!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
